Haven't read the rest of this thread, but... I'd like optional angled connectors. Many boards now have built in 90 degrees sata connectors - why...
Asus P5Q ~ £85 E7400 ~ £82 Akasa 966BL ~ £23 Adds up to £199.42 at Scan. The P5Q should have the connectivity you need. The 966BL is rated...
The what? :sigh:
I just bought a 1/24th scale Delorean off ebay in Back to the Future Part I style. I'm going to mount it on the dashboard of my car.
[img]
Fail. :D
[IMG] [IMG]
Broadband with 02. Goes up to about 8Mbit I think. I also read bit-tech reviews on my phone when I'm on the toilet.
If I might interrupt... [IMG]
Your hardware all seems up to scratch. For 3.4ghz you'll need a fsb of 377mhz with the default multiplier of 9. On my Q6600 this would need a...
I've moved the lights off the panel and onto the chassis. This helps things, the upper string is just hidden by the upper frame of the PC-7....
Increase your blade count, to something like 10. It'll drive more pressure, though there will be diminishing returns after a while.
Oh I agree. I'm looking at the case now and it bugs me a bit. The thing is, I wanted to make the window is as large as it can be, and now...
This morning a nice package arrived from China with two 48cm strips of white LEDs I ordered off ebay. They were only £8 and I thought this might...
[IMG]
Holy ******* ****, that bird has a car alarm and a chainsaw! That's far beyond what I expected. Some awesome potential for some video editing...
Paperweight? Building blocks? Murder weapon?
So RealTemp is right? What Tjmax does it use? Cause then I can just whack that into CoreTemp and suddenly I'll be one of the enlightened few.
What do you use for measuring that, out if interest? CoreTemp? And have you lapped your TRUE?
Mighst all Chrity, I wasn't expecting a damning critique of my cooling setup. So I should have just 7 degrees difference between my CPU and...
