Yeah, that texture is a byproduct of the injection molding process. The textured of one side of the mould is roughened up to prevent it from...
Newer thinner drive are 9mm. But I'm unsure if the traditional IDE adapters work with those or not, and even if they do you still have the height...
If it's a normal 12mm height 50-pin ATAPI slimline drive then it's the same size as all other 12mm height 50-pin ATAPI slimline drives. And the...
Today I had other things to attend to but I managed to make a filling funnel. [img] Instead of the fillort I'm going to be using just the valve....
To make the Nerf gun more fun I made a PVC backpack tank to replace the tiny stock bladder tank that was inside the gun, then I combined the two...
Well, my health for entirely unexplained reasons and with no help from the medical realm has improved over the past 2 weeks. I have all but given...
Bumpy effect? I have no idea what you're talking about but generally it's not a very good idea to sandblast plastics, espcially acrylic.
clear coat
Most hair-dryers will not be able to reach the temperature levels required to warp acrylic. Even the cheapest heat gun you can get will...
I have a Socket A/370 block if you want it. It has 3/8" barbs though.
http://www.excesssolutions.com/cgi-bin/item/ES2787 You might want to hook it up to a fan controller... I also HIGHLY recommend these...
The length of the holes is not an issue. Longer length drill bits are easy to find. Drilling out screws that are holding together plastic devices...
If you're using a rotary tool you have to use a toothed cutting disc because abrasive bits are pretty useless with plastics. Cutting faster with...
Triangle Recess (TP3) screwdriver bits are rare, but I've found several sources including mcmaster.com (search for part# 5941A13)....
A few minutes poking around in the Mouser.com catalogue and it's a 3M Mini-D Ribbon Camera Link Standard Interface Cable. See page number 973...
Jigsaw. Dremels are crap for working with large cuts in sheet metal and if you do so you'll end up burning through loads of cutting discs.
Rotary tools and plastics don't mix all that well either. THE best tool for working with plastics is a combination of a scrollsaw, a set of files,...
Get a jigsaw instead. Dremels are only good for detailing work. For work outside of that usage they'll just be a huge waste of money. Especially...
Wow, I'm hooked all over again. I don't think I can manage to post any more than that after seeing tonights episode. The only annoyance: DAMN...
Aluminum Fractional T-Slotted Framing Systems come in a wide variety of sizes, but it looks like lubic is only offered in 1" width. You should...
