I give you option 3 by this week. I hope you will like it :)
Why not a Merc Beta then?
http://www.overclock.net/t/1296642/watercooled-bitfenix-prodigy-build Something like this?
Baz, Triple rad mount on roof, and front (or 240 on the bottom). And there fan filters on the front.
That sketch-up looks awfully familiar... :eyebrow: I think Prodigy will come as close as it gets to the sketch up.
If you do, or planning on, PM me. I have suggestions. :idea:
160mm non modular PSU's do fit... Nice use of radiators :) Anyone try 200mm radiators?
Depends on the width of it, if it will hit the ODD cage with all the fans installed. [IMG] From the looks of it, the fan farthest away from the IO...
or, I'll post here: Dxhxw 34.04cm x 30.74cm x 24.14cm P.S AX 850/750/650 will fit. They're the same size, and I have 750 an 650 confirmed to fit...
Aussie's have them already. They were the first this time.
I've never really appreciated orange on any case... Until today. :geek:
1.Use the PCI slot for a Raid card. That's the beauty of being flexible. 2.Without it, you will have no room to place any hard drive spaces with...
On a good day, we'll go our for pizza. :rock: Then we go out for the drinks. :D On a more serious note, I'm glad you love it. I met one of...
If 160mm is the max, why would 140mm be recommended when 150mm fits just perfectly fine? I'd say 150mm is the recommended size of PSU for a full...
