Sweet build mate, loving the plexi feet :)
fine, should be some photos showing the edges along with a video I posted on the last page that shows it from different angles thats if your...
Thanks alot Tath. good luck with your desk build, going to see if I can find it now :) lol thanks
lol, Thanks again Bart! will be sad when this is over & i no longer get to make your pants happy :( thanks Mic, going to try get a friends...
fantastic work mate, & your just up the road from me :) Hudders
Final update for today & im happy to report Iv bent my 1st hard tube with success :D Using 16mm Alphacool hard tubing with the 16mm Alpha...
Fenix has helped me out by getting most the logos laser cut for me along with 2 360 RAD covers that I plan to wrap & add some bits too later in...
Going to be a busy week, wife due to pop any day now, more packages have arrived that i've been eagerly awaiting so I can get to work on the...
This is going to be one of the bigger updates, mainly because i forgot to add some bits earlier in the log & iv also decided to cover my desktop...
Nice to see some1 else using tights, just finished adding some myself ;) far better than filters from the shop so long as you don't get any...
Thanks, The parts I did 1st are rock hard, others are still a bit softer but not scratched any of them yet :) think they will withstand most...
this is the shell, Done :D time to work on the belly of the beast!
thanks ;) looks like everyone is going to win, or at least be very close :D...
Cheers mic, sexy is good ;) -------------------------------------------------------------------------------------------------- Almost...
Thanks Bartacus, Im hoping its very stealth so I can keep gaming all night long :D Should have also mentioned in my last post, Iv started the...
design on the top looks great! fast worker
Thanks for adding me to the list :D & good luck to everyone, all great projects :dremel:
Got my paints & been working on the smaller parts of the desk, wanted to double check the finish & practice applying the paints before doing the...
Clips look great & the build :thumb:
Evil Bean broke the desk in 2, will use this to my advantage & do the Prep work before the final paint... :) [IMG]
