Thanks for the reply, Deders I've tried plugging it into different power sockets in my apartment and connected different devices and,...
Hey Guys! Back in 2011, I purchased a wonderful set of Creative GigaWorks T40 Series II from Scan which were working perfectly up until last...
Thanks a lot for the replies so far. I'll contact the supplier and check if it's under warranty first. Enjoy your day!
Hey guys, One of the three fans on my Gigabyte GeForce GTX 570 OC card has decided it's had enough and is dying a long and very loud death....
It's definitely not my USB devices (I only have wireless dongle, keyboard and mouse plugged in) as I unplugged everything except my mouse and it...
Many thanks for the reply. Windows Update thinks everything is up-to-date and I will check my BIOS now. Here is the result of the powercfg:...
Hey guys, I recently upgraded to lovely Sandy Bridge system (see sig for specs) and it went without a hitch EXCEPT one little annoying problem:...
FIXED BINGO! Thank you so much! I dropped the speeds down to stock and it's been fine for weeks. :thumb:
Thanks a lot for all the replies. The original reason to keep the XP build was so I could play a few newer games for the next week or so then...
Hey Guys, Hope you can help... I've just upgraded the CPU, Motherboard and RAM of my computer and (naively) thought I could just uninstall...
Even though i tried the card in a friend's computer and it ran Furmark @ 1600 for 2 minutes without failing? Image of the lines on my screen (but...
Another update (hope this helps): 1. I have uninstalled my previous gfx drivers (safemode, uninstaller, driver sweep) and reinstalled the very...
The motherboard? Edit: As far as I can see all the capacitors are intact on the motherboard
Hi guys, Apologies for taking so long to get back to you all - I've only just had time to pickup a new PSU (Antec True Power 650W) and...
*FIXED* I just lowered my GPU speed back down to a generic 260 stock and it's fine. Thanks to Instagib! Hey guys, Whenever my PC is under any...
