We moved to a new build (bought off plan) in Oct 2013. No phone line at all n the property and arranged for BT to come out 4 days after we had...
will this work with the drive in a usb 3 docking station? or does it physically need to be plugged into one of the sata ports inside the computer?
Recently had to re-start the above named drive, and when it had re-booted it was not recognized at all. Seems this is a common fault with these...
would be okay to play if we could actually install it - http://steamcommunity.com/app/209000/discussions/0/648811126460953448/...
thanks for the reply's - but as docodine above has pointed out - as I am running Linux as well, I'm better off sticking with the green camp. So...
What's the opinions on the GTX-660 Ti? I've been able to push the budget by another£100 to around £260-£270 so I can squeeze in a cheap 670 or...
Not too sure if this helps - but I am running an AMD FX8120 & Asus Crosshair V (AMD 990/SB950). Would an AMD card run better in this setup...
The time has come, the walrus said, to speak of many things........ IN this case - time to upgrade the graphics card. I currently have an MSI...
Sorry - no can do! work 9-5 and do not have access to this sort of thing at work - have access at lunch time as there are a couple of PCs in the...
Thanks for the comments so far. Unfortunately, the Samsung 830 or 840 are outside of the budget that has been stated - my usual supplier has...
Okay, as the title suggests I'm in the market for a new SSD. Currently have a Crucial readSSD 64gb which was purchased just under 2yrs ago. At...
Thanks for the comments so far - lancer778544 - i have already looked at these - and as we have a richer sounds not too far from where i live i...
£200-£300 max
HELP!!!!! To all my esteemed bit-techers! I am currently looking for any assistance with the above - i already have a blu-ray player so only...
I had the Limited edition of Alan wake on pre-order - didnt arrive in my local store - spoke to customer services and was told that it had only...
but have you noticed that it's only on-line retailers that are being shown - seems no high street stores will be selling it. Read the comment on...
from what i've read on another site earlier on - the 8 core are likely to be around $300 or so (current exchange rate that works out to roughly...
i've had my CH5F for the last week - great board. No set-up problems at all - booted first time of asking. Yes it's an expensive board for an...
if you get chance, visit Arromanches. This is where the floating harbour was built to give the allies a harbour before they where able to capture...
a lot of places - mcdonalds especially - have free wifi - when my wife and i holidayed there last year, even my toshiba TG01 windows phone had no...
