@David and @mnpctech , I appreciate your like and sharing!
The machine is completed at this stage. [img] The operating system is Ubuntu MATE 16.04, with a custom theme. [img] I placed the machine on...
Thank you! You can try it and like it!
Then I took care of air intake. I designed and 3D-printed a turbo fan, no, a turbo fan-shaped fan grill. [img] Tiled up the turbo fan, a random...
Then I am going to make a curved fairing for the engine. I decided to make it transparent. All I wanted to show in the hardware inside the...
Thank you for this very detailed instruction! Will try on my next build. There is a lot I need to learn. :cooldude:
Hi @SiZZiGY Thanks! Actually there is a 2nd step pad between the HDD holders and the rails - the stickers. They are thin, but they should still do...
The size and shape of the motherboard is precisely enough for covering four HDDs aligned laterally. This maximizes saving of space. This is among...
The C8220 motherboard doesn't have any 3pin or 4pin fan connectors. To control fan speed I installed an external temperature negative feedback...
Hi @David, your observation is very careful and correct! Yes I switched the board, because the first board was fried in a failed voltage modding....
The two CPU sockets are elegantly aligned in the middle line of the motherboard, apart from each other at an elegant distance, thus allowing most...
@Kim, thank you! I had this aesthetic envisioning in mind before choosing the motherboard and the coolers. They were born to fit each other!
Below the PSU is where graphics cards can go, with a left-angle PCIe riser. There isn't much room. But as I measured most low-profile cards and...
I did cable management using artist's wire. [img] Look! [img] [img] [img] [img] [img] [img]
My Corsair RM650x PSU. I love this thing because its edges are filleted. One of the only two problems is that it has some "sensor" sockets in...
Thank you!! I played with several Dell boards and PSUs. Haven't seen a clear clue. For their multi-rail PSUs, each +12V have different colors:...
@storm-83, @HandMadeAndroid and @Cheapskate, thank you!! :clap: The temp is about <40C idle / < 65C load. I am quite happy with it^^ Basically...
Before I expand please meet WarpDrv's predecessor (noname yet). It's based on a comparably shaped motherboard - Supermicro X8DTT. And it is likely...
Hi all I like riding bicycles. I am new here. I wrote a long post in build log forum but the post disappears, nor can I reach the admin. It says...
[IMG] Hello community! As a beginner here I present you a workstation I built for my own use: Codename "WarpDrv". It is already completed. I am...
