I am using the Saphire Vapor 2GB HD4890 with an 24" and a 19" screen and have no problems. You will find that the GPU is up to it.
Welcome to your first post on this board SpikerSurge. You will always advice here, but it sometimes may take a while so never give up. As for your...
I got a 2GB 4890 Vapor-X and I will keep it at least for another year or so till it makes sense to get a 5870 Vapor-X. At the moment all 5xxx are...
yes it is and it says that its working properly and the driver is up to date as well.
Hi all, just got a slight nagging problem. I got a Logitech 2.1 speaker system that is working fine (when I connect it to any other computer) but...
Hi all I sincerely hope that someone may be able to help me out. I am changing my OS to Windows 7 Ultimate 64bit on the 22 October when my...
Hi all thanks for all your help so far. So now that I have settled on the ASUS P6T Deluxe V2 with an i7 920 D0 i am now staggering with the...
Could someone please let me know, now that the HD-DVD officially has been shelved is it true that there will be a Wii with Blue Ray hitting the...
I usually use Scan or ARIA (got accounts with them, thats the main reason). Both told me that the stock is overdue since end of June. The retail...
Many thanks for that. Will check it out and list myself on the notification list. I am after it in about 4 weeks when I build my new rig but if I...
Does anyone knows where I can get a Corsair Cooling™ Hydro Series H50 CPU Cooler from at the moment? :confused: It seems that all retailers are...
Hi all As you may I am at the final stages for deciding a new build. Please bear in mind that the build will become A BACKUP SYSTEM ABOUT SIX...
Many thanks for all your help. I realise that it will not be easy sailing but having to pay every so often for Programs from M$ does my head in. I...
It's a very 'old' program thats called E-Converter V1.22, it cam in a zip file that contained an exe file called Econ.zip and is/was...
Well what can I say. Thanks for all the input. So, you guys/galls reckon I am better of just to get my paws on Linux Ubuntu 64bit? I am using the...
This is making me now a bit nervous and giving it a second thought. I am an absolute newbie and this will be my FIRST Linux program ever and need...
Hi all, it will be the first time I make the jump over to Linux Ubuntu Studio. I will have a new system for it around an ASUS P5Q Deluxe with and...
:thumb: Last MM and CCP all where ranting about that it would be cheaper in the US. Now I am really confused.:wallbash: As for the 64 or 32bit...
Did not know that with XP. Anyway I will wait for Win7 Ultimate to come out. Have to go to the US every 3 - 4 month anyway and will get a copy...
Yes, Windows XP Pro at the moment, but I am planning of building a couple of new rigs and would like to make use of more RAM and install Win7. Its...
