I Would get this http://www.scan.co.uk/Products/1GB-XFX-HD-4870-PCI-E-20-(x16)-3600MHz-GDDR5-GPU-750MHz-800-Cores-2x-DL-DVI-I-HDTV-HDCP Or this...
Will be upgrading from my Freezer 7 to this in a Few Months, its the Loudest thing in my Case, so its got to go!
Change the Formality - Infected Mushroom
Is it not possible for Valve to Update more than one class at once? I Mean, Updating the Sniper makes the Spy a little less useful, so they also...
The 275's are More Powerful Cards, but also Cost more. If your SLIing 2 275's, you may aswell get a 295, its cheaper, and essentially the same (A...
Whats the Highest a Factory Overclocked Card has Gone? Not sure im going to get very far with my Palit 275, as its based on the 280, and seems to...
So, would i just change the First 3 Numbers? Or Would i go 4-4-4-15, then if thats stable, try 4-4-4-14? Thanks, the E7400 is pretty easy to...
Right, got this to happen :P [IMG] Strange thing is Orthos and W7 Say my CPU Speed is 4200Mhz, but i know its 400x10 and CPU-Z Shows This. Only...
17" MacBook Pro, maxxed out Spec. Not the Most Powerful, but you wont mind when you get an 8 Hour Battery Life.
[IMG] Just simple, might try and theme it a little better, but W7 doesnt have many modding tools yet.
I Would Definitely get the 2408WFP. The response time is high enough unless you need ultra fast response. The Colours are Superb The Design is...
Fallout 3? Similar to Oblivion, but Post Apocalyptica.
Can you buy a 750, and unlock it....?
Im a Complete Noob at this, what would be a Looser Setting? Stress Test is nearing an Hour at Stock CPU Speeds, but the Memory is at 400Mhz not...
The CPU at 4Ghz is completely stable if i just test the CPU, so it must be something to do with the RAM.
I Have set the CPU to Default Speeds, and set the Ram to 5-5-5-15 at 2.1V, Orthos is Running now. Just wanted to see if its the CPU OC Causing it.
Double Post But.... At these Settings, the RAM Fails after 11 Minutes, when stressing just the RAM in Orthos. [IMG] Gonna set the E7400 back to...
Well, Cardboard begins to burn at around 100c, maybe a little more.
A Guy is Making one in the Project Logs.
A Little More Help....? I Did want to see if i could lower the Ram Speed to 381, to get a 1:1, or maybe change the Multiplier and Run the CPU at...
