Totally agree that they should be made better - certainly packed better. The ones I had broken were from two different orders: 1 on my first...
I can't say how much force it would take to crack one. But after seeing 3 broken upon unpacking, I've been avoiding handling them by the Tees as...
Nexxo, The L-bend connectors are nothing more than G1/4 Koolance right angle nozzles. With my design, I wasn't able to put a radiator stick...
Have you looked into a passive radiator solution like Alphacool Cape Cora rads? No sunlight, natural airflow... no fans or enclosure needed......
I don't mean to jumpstart and older thread, but I just finished a build of mine based on the Alpha Cape Cora passive radiators. I wish I had...
