No refund yet Yorkie. Will see if it goes in tomorrow.
Why do users have to use BETA drivers? You'd have thought they'd write certified drivers and have tested them BEFORE releasing the new cards.....
Just intrigued as it was a ballache installing my Dark Rock Pro Advanced! My ThermalTake Element S case DID have a cutout to install the backplate...
But what cooler are you using? I should have really posted what are your temps using only the standard intel cooler or an aftermarket...
Well I just ran mine the same test you did and you can see my i7 2600k hit 61C max after 5 minutes, [IMG] Which as you can see is 16 degrees...
Just spotted that as well! What's with the cable tie holding the fan in place Lenny? Lol.
Well I would (it looked pretty flush/seated right when I fitted it though) but that would mean taking my whole pc apart and unscrewing the...
Jizwizard it's interesting yours says CPU 28 because your four cores add up to a total of 141 degrees and if you divide that by all 4 cores it...
Dark Rock Pro Advanced, nowhere near as good as the Corsair H100 you're using though so I can live with my temps I reckon :) Right now about...
:eyebrow::eyebrow::eyebrow::eyebrow::eyebrow: What's with all the negative posts! Jeez give them a chance before you make your minds up!!...
Ok cheers for that Yorkie. I'll look out for the refund early next week. :)
I've just installed one and this is the idle temp, this high or not too bad? I think it's ok myself :) [IMG] Also what cooler you using with...
I don't think this is as bad as people are making out.. I mean in the article James clearly says, Can't be that bad then surely! Give him a...
Ok will take a look. Thanks again.
Thanks .//TuNdRa, The Element S it is then, I'll go and get it today so I can finally finish my build, which after changing my mind and rma'ing...
Excellent very thorough post. Thank you :)
Pretty gutted 127 views and no one could (or would) answer and out of all the technical people on here I thought at least one of you could clarify...
Need a little input please :) Because going to get a case in the next couple of hours. Cheers all.
Hi Yorkie, You work for CCL I presume? Anyway I believe this is being dealt with by someone called Nowell, I returned several parts under the...
Anyone? :(
