OK found my answear here http://www.overclock.net/t/1220895/problems-with-recurring-bubbles/10 block on this page is running them off his gtx470...
This is the pump I'm talking about http://www.swiftech.com/mcp35x12vdcpump.aspx in the manual it says to plug one wire into a molex connecter and...
Was just reading on another forum those pumps have the pwm connector and a seperate cable for power is that correct if so that would make it...
Hey all wondering if anyone can explain to me how pwm works on a video card is it controlled from the video card BIOS or does the motherboard...
Yea just a little peeved I did not think of this being a factory oc card I assumed there would be a full cover block I will wait and see how I...
Im guessing for the gpu ram some of these http://www.swiftech.com/mc14bgamemoryramsinks.aspx and for the vrm area some of these...
Yea have been searching for about a week pretty confident there are non available :-( . When using the gpu only block is it only the video card...
Anyone know of a full coverage water block that fits the gigabyte 1GB 6950 model GV-R695OC-1GD...
Wicked croc skin on a case has to be some sort of first awesome stuff:-)
Coming together nicely!
Cool I want a cnc machine badly :-). I think I will go down the DIY route and am looking at a laser for cutting aluminium and plastic and burning...
They looking good. There bottom photo is what I will be aiming for with the max of the grommet closest around the cable. What sort of glue did you...
Look good but I have opted for rectangle holes wich have already been cut :wallbash:
Yea I saw that. Its not so much the material it is the fact when a cable is pushed through, the slit is open most of the way along. I was thinking...
Thanks :-). Looking at the video again, I don't like the way the gromet sits with a cable through it thinking maybe a combination of a slit and...
Cool will be interesting to see what they are like. Do you have a link to the foam? I am still undecided weather to use grommets or just use edge...
Definately souends interesting has crossed my mind more than once to give this a go. Just watched this...
Hey all wondering is it possible to put a drainage plug into a swiftech MCR320QP radiator it is one of the non stack able ones that just has a...
I am not very good with a spray can and after doing some research have found out people use bee's wax. Anyone tried this? Sounds good and after a...
Personally I think live Modding on Skype is a good idea one step beyond a video tutorial:-) love your work and keepon Modding !!:rock:
