Looking at the partially assembled product is like looking in a toy store window, unable to walk in. Looking at the case I can really see how...
There are no words to describe the beauty of that Assembly. You had better patent that fast before Apple gets wind of it. ^_^ So, if you were...
Waynio, for that heat pipe issue. Next time I would try making a flat plate that matches the curve of heat pipes. Use a scrap piece of metal....
Very cool to hear Bill, and I look forward to a Star Wars tribute build.
That is going to be the Power Button to end all Power Buttons. Truly amazing, I can't wait to see it in it's full Power On Glory!!!
As I said before, this has got to be one of your best builds. And that paint job is amazing.
Dam Cheap, that would look smokin hot. Good Idea
Well, I have heard many criticisms and accolades. I have also looked at each of these work logs. Again, some great work going on. In looking...
I have to mirror my thanks. I never expected to nominated for MOTM. Thank you. I too am not finished yet, however I will and I hope you...
Oh My GOD Bill, this is amazing. I think this may be your best build yet. I love that Tach', Can wait to see that in action. As always,...
Wow, that's truly some amazing work.
I've never seen this many posts without so much as a pic of a case, or something. Even if it one that is in the dumpster and is nothing but a...
Hello everyone, well, sorry for the delay in getting an update out. First off thank you for those that are following along, your praise means a...
What a great hardware switch. I love the detail in the cabling, and redoing the wires on the pump, that's just crazy. Cool, but crazy. The...
Was this build for a customer? I especially love that res, you turned that case into something that folks may want to buy just to turn it into...
Well, it’s update time, and it has been a little while since my last update. Things have been moving very slow. Weather has been a bit part of...
That's really something. One of these days I'll have some Big Boy Tools.
OOOOOOOOOO, This is to good to be true!! Break out Note Pad, Check Screen Capture Program, Check Subscription, Check Dam, forgot the coffee, now...
Wow that is an amazing design, and those cuts are great. Most certainly sub'd on this one.
Thank you all for the compliments. It's always nice to get compliments and not just views. Bill, that green paint on the one piece of white...
