I just ordered a set of Gskill 2gbzx from newegg, having a friend ship them to me from the US. Running 512mb is becoming a problem for me,...
1250 is not high wattage (from memory its about 12watts) So thats not a jojor ammount IMO, especially if you use it in paralell (not submerged)...
I do like the way that Bit review graphics cards. Comparing the competition by playable setting as opposed to pure FPS has its advantages. I...
More fans or bigger rads will only help if your water temp is high (more than 3-5*c above ambient) Best thing you can buy is a temperature...
RS will sell you a single unit (but it will cost you) www.greenweld.co.uk soemtiems have comair stuff, but they have a random selection and...
My pump is mounted within a HDD cage from a lianli case and is suspended from strings.. This stops all vibration and makes the pump silent...
When I was at uni and had less money and a modem (no MP3 Dl for me) I spent allot more on music now where I have more money and 2mb broadband....
I think you should be able to use epoxy to stick somehting to the back of the hole (steel aluminium or whatever) to give it some strength. Then...
I love my dremel, but for cutting a case window or blohole its just clumsy.. Buy a holesaw or jigsaw... so much easyer.
Pretty much as good as each other. IMO.
You can allways return items you bought online for a refund as its the law!! To protect customer from this exact sort of mistake.. you might...
My compressor was £150 ! If its good enough for airbrushing, its 100 times good enough for dusting my PC. I dont think you will have much...
I just use my airbrush compressor for the same effect.
Im amazed.. I would normally not post in these types of threads... as its allways excuses why they didnt call, or make any effort. nice one...
I recomend that you fix one of the motherboards standoffs onto the PSU earth, just to be safe. You may also need to wire an earth to the PSU PCB...
It might work better with the fans sucking air through the shroud... as opposed to pushing it through. But its still a cool way to run your...
You can probably just give it 12v from another source as well, save you risking getting your PSU wet.
Are you 100% sure that its the MCP chip thats loose. Sure its not a grounding issue or something else. Those types of chips are pretty...
Like the other guys say it should work fine. Might get slightly worse temps especially at high wattage, but I dont think the difference will be...
One word BONG!!! Do some searching for bong watercooling. This will get you below ambient (maybe significantly in 35*c ambient temp)...
