just so I don't have to start a whole nother thread, heres my problem I'm running a dsl connection off of 2 switches, one for my downstairs and...
in terms of internals, I believe maximum pc gave them something like a 3 out of 10. I'll try to find the article.
:D
shouldn't a mono jack work fine?
you mean a molex pin remover? you can buy them or go check out the guide thats going on right now in mod guides section
incredible. What method did you use to get the decals on the top of the case?
this probably would work better if you posted in electronics, but you're probably not going to get a good answer until you post the lcd #, or some...
jukebox zens use regular old laptop harddrives. http://www.extrememhz.com/zenupgrade-p1.shtml
yep, that answered my question, thanks.
double scroll wheel mouse? thats hot. this looks like its gonna be an interesting project to follow. Thinking of doing some inner cabling like...
sanding plastic comes out fine. to compare using the things I've painted, a mouse and a cell phone cover - the mouse got sanded, the phone cover...
coffee making computer (bottom of page)
I've only got like a min. left here at school, so I didn't have time to search, sorry guys. any ways, I was wondering if there was a way to use...
I painted my 21" crt blue before it died. I removed the plastic that housed the main part of the monitor, and then put newspaper around the...
I've always wanted to make a submerged setup with gordon F. walking on a catwalk over one of those giant green toxic tanks (with the pc at the...
ah finally this is getting made. Are you gonna gloss this one or go for a matte finish?
gonna pull this one up back from the grave. I got most of my stuff ready for the serial port. If you guys will provide schematics I'll take a...
If you slip the hd into a zip lock bag, is there change of it getting ruined by static, or is that a way we could more easily do this w/ one hd?
I'll get it to you on thursday :) but thats pretty expensive even if it is only about 2 pages of stickers
anything new???
