you could go the 4pin mic jack route like ZapWizard used for his ammolan.. kinda hard to confuse one of those.
My guess: The capacators are fried. If you open the case and find some brownish looking goo (probably crusty) then you have bad caps, and need to...
you could probably use an ignition switch that is meant to flip itself back after the alternator has turned.. like in a car.
White smoke coming from the vatican means that a new pope has been elected. howabout setting an entire matchbook on fire and then blowing it...
i suppose you could go to a scapyard and look for an old electric car window motor. but those are large and not like hydrolics or actuators
if he was just going for the pumpkin look i would have used a foam pumpkin and a mini-itx board. lol.
get some led holders and put leds in the holes and turn them into something.. maybe like power and hdd leds
i forget where but i've seen someone building a full sized micro-atx motherboard into a hummer model from walmart
http://www.canadiantire.ca/assortments/product_detail.jsp?FOLDER%3C%3Efolder_id=2534374303515781&ASSORTMENT%3C%3East_id=1408474395348027&bmUID=1091...
hers what i'm trying to do. [img] have strings of leds powered off of a molex in the xbox and triggered by the origonal led that goes on and...
well heres the scoop. i want to help make my friend have a really unique xbox so i dreamed up a way to make an ufo effect on the bottem.. with a...
find some way to make a slideshow? preivew pics on a compact flash card ( :P ) I GOT IT! make a prgram that has an eyeball spinning around and...
i did that with a heaphone wire spliced into a speaker for my walkman. but unless your speakers are magnetically sheilded i wouldnt put them near...
it could be cool but if you do do something like this your should probably do it with a two position 3 pole switch si that you can have the led on...
i swear i have no idea how it fell off the wall into my bag ! :rolleyes: :lol:
maybe just attach the leds to the plexi window and your etching should light up witch may have to be a last resort for lighting or i havent been...
www.canadacomputers.com they also have physical locations
i read it in english using altavista bablefish.. its not 100% good grammer but you get the idea.
me neither. i think your shaw hosting is down cause i cant see you movie of you rippin the ram from a mobo
me too. it suxs i cant even build a cmp to mod so i just keep getting ideas and reading up on stuff :sigh:
