I've seen that happening on a number of networks / ADSL connections - including BT, Tiscali, Plus Net and others. I can only guess that the lag...
Media Centre can be difficult to get to play nicely on a network - I think it is because MS chopped chunks of the networking out for that build...
Yup, also, I assume you do not have a domain server running? If you check that the username exists on both machines, and the passwords are the...
What OS on the machines? XP Pro? Knock the 'Simple file sharing' off, as this can cause horrific grief in my experience. Then manually setup the...
I'm on 2Mb Plus, BitTorrent speeds are crap during the daytime (peak use?), but fairly impressive at nights (100Kbs + some times). If I was...
Another Trillian user here :) Only because I got fed up having MSN Messenger (along with all the CRAP integration that it brings), Yahoo...
Thought I'd jump in, although things have gone quiet :) New user to bit-tech and all that ;) The kernel, although initially intimidating, is...
