Input of 240V AC (UK Mains) Output connector not inportant, I can solder one on.
Hi, I am looking for an external PSU that is approximately 80Watts with the following spec: +5 (~5Amps) +12 (~4Amps) -12 (~0.5Amps) I...
I am making a Power supply box, for various types of 12V lighting. I just need an easy and quick way of connecting them. The IDC terminals look...
It will work (assuming there is nothing else wrong with the LCD) As long as the replacement caps are the same or higher Voltage, and the same...
I am looking for an Insulation Piercing Connector/Terminal. All I can find is one made by Belling-Lee below, but it is way too expensive (+£10...
Have a look on ebay for rack / 1U / Server Power supplys, some of them are quite small. Also have a look on the mini-itx.com/store
Nice idea. It should be possible, if you add a normal dial up modem to the PC, and give the PC its own phone number or extension at work. Then...
You could use a LDR, in a box so that only light shining directly (from the laser pointer) will hit the LDR, and avoid the sunlight / other light....
Have a look here: http://www.electricstuff.co.uk WARNING: Van de Graph generators and tesla coils can generate massive voltages, more than...
12V to 9V I had the same question, answered here: http://forums.bit-tech.net/showpost.php?p=1052559&postcount=8 Thread:...
Here is the correct diagram: [IMG] Piranha LCD looks identical to the "Wild Things" one I have. I've managed to link up the WildThings LCD...
I think they cheaper on eaby. maplins always a rip-off.
Hi, Thanks all for your comments. The reason I am thinking about doing this - is not for overclocking or any extream cooling. The aim of it is...
What do you think of my idea. Its to cool a 733Mhz Celeron. Think it will work? Parts: Normal CPU Waterblock, Very Large Heatsink,...
You can use a cable like this: http://www.ebuyer.com/customer/products/index.html?&product_uid=21926 To move your USB from front to back -...
Yes, it is possible but not easy. You will have to program your own Microcontroller. Such as a PIC based one. There are some articles on...
Hi, Thanks all for your help. I've done a stupid little digarm of what I am going to do (as bigal described) [IMG] (I could have used...
The PSU is only connected to Motherboard and 1HDD. No Floppy or CD-ROM's (not even a keyboard or mouse). So I think the 120W should just be...
Hi, I would like to power a router and a switch from my PC's internal power supply. My PSU is only 120W and has on the label: Input:...
