Actually, 500/533/550/566 will work on AMD:D. Use all four in different boxes I have. It just defaults/recognizes to 400 on boot up. Using 550...
HI, I don't use EMI so I can't offer any opinions. It is Great to see you at the top, it seem the production of registered folders versus...
Careful now:D I might just put my other 5 online:)
Been there done that:D, on my own drill press:D hole punch is far easier and I don't have to remove everything from inside the case:) I...
HI, In regards to the CNC; I am an expeirenced toolmaker[although not exceptional]. The HAAS mills and lathes that I am required to operate,...
HI, I recently started 5 boxes for us and when it cools off here later this year, I will start back up 3-4 more. It is not nearly your...
HI, I use an old PSU to power my breadboard. I just hooked an old small Hard drive to it. Works good:D
HI, I have had several orders delivered exactly as you mentioned. They arrived fine:)
HI, I have bought several different model FLUKE meters at pawn shops for a REAL good price. All work very well. I sometimes use two at a time.
HI, I ran across this; http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7529516127&category=4666&ssPageName=WD1V&rd=1 An it led to this;...
HI, The case appears to be plastic, just a sick green. I had done several hours of search and could only find distributor inventory. That is...
Hi, I was afraid:worried: someone would ask this question.:blush: I received several orders of miscellaneous parts from multiple sellers and...
HI, Thanks for the response. It has 3 legs and looks like a IRF530,for example. A real pale sick looking green:( edit: it might be...
Hi, First time poster, please be gentle:D I have spent some time trying to find a data sheet on this item. It is in a light Green To220...
