I don't see those rubberbands helping anything, chances are it made it worse. I have a 2.5" drive in my dash and a 3.5" USB drive...
I played this on my secondary system (see: old), and it was very playable. Specs: 1.73 ghz amd Geforce 4 Ti4200 512mb ram I played at...
Where I'm at now: I'm ditching the ball idea and going for 6"-12" tubes. The test ball we made wasn't as easy as I thought :) It came out ok, a...
Thanks for the reply. I think I may look into PIC programming. WIll I have the same problem using a pic setup with only using 3x AAA...
I'm trying to modify this circuit to take a 3.6v-4.5v source (3 AAA), while powering 4 LED's in the same fade pattern. From what I've read, the...
I used to power a car amp and subwoofer off an old 200w PC power supply. Unless your amp is a good name brand, it will output nowhere near whats...
Im going to try a couple small test balls today, if I can get the stuff locally. I'll be using the high priced/low output LED's from radioshack...
I'm more worried about the LED's heating up while in use, rather than damage from the curing resin. Unless I add to much catalyst :)
My goal is to illuminate a 80mm clear-solid polyester resin ball. I've seen a couple projects with LED's in a similar environment. My inital plans...
I missed this thread somehow .. but nice work! I have built a cocktail mame (Nintendo vs cab), and I have a 2 empty full size cabinets in my...
I'm taking old car wiring diagrams from many different sources of variable quality and I'm attempting to restore them in digital format. So...
Whats the best free or cheap webhosting out there? I doubt I need more than 10 megs and bandwidth will not be an issue. Just looking for something...
I like ReikoX's idea. You could even build a small plexi box on the bottom (false floor) which could act as a tank reservoir :) Just put your sand...
:thumb:
