That might explain why its has been flashing up saying my accounts in use on another :\
Make it mind controlled instead of sounding like a tool talking to yourself in public then i think their onto a winner.
I just checked on Scan, i bought a 1TB Samsung spin point F3 a month ago for £42 now its £98.13 .. :jawdrop::waah:
Good review but I'm disappointed that nothing from OCZ was in the test.
Best: Gainward GTX460GLH Worst: A HP pre built machine, with the amount and range of parts i have had to replace i should have just built one...
i agree with whats being said you should have more than enough power just make sure you power off both 12v rails to spread the load.
What sort of budget are you working with?
I think you get 10 installs per EA account as the serial is linked to that account so just log in and away you go.
Agreed.
IMHO its all one big grey area that is not well managed by the ISP as you can have two people on the exact same package and one get throttled /...
This is just amazing work! :jawdrop: keep it going! Subbed :thumb:
Now i do :) thanks for the answer.
I Apoligise now for the following stupid question. Looking at the "folding cost efficiency" graph a GTX460 1GB is at 65 ppd per £ and a 460...
:jawdrop: i'm Glad your ok,
Two very good suggestions :thumb:, i don't think that motherboard will be able unlock the disabled cores on the chip though. My only concern...
Amazing work! :thumb:
I have come across soemthing similar; we got round it by adding in a generic PCI Nic card just to get the PC directly on the net so you can try...
