http://www.rockdirect.com/ I'd recommend one of these laptops, built like a... rock? In all seriousness though, they're awesome. i7, 4 / 8GB...
If your mounting is correct, it may very well have to be returned. Sounds like the battery isn't connected correctly.
I would say Windows 7 definitely. Ultimate is not, and never is, necessary. You may as well just go for Home Premium, or Professional if you need...
I've heard a lot of good things about Western Digital external drives, like the Passport ones. I believe they just released USB 3.0 versions of...
I really would love the Signature edition... Can't afford it though :/ More likely to just purchase NFS:HP & Standard GT5 later.
I'd recommend using Microsoft Security Essentials to keep your machine free of viruses. It's all I use, have no problems. It's light on resources,...
That build looks pretty good, prices won't change much if at all in a month though. So you may as well buy it now and get building straight away :)
You would most likely have to do a re-install, never tried that myself. However it may work... I guess the only way to find out is just to try but...
Vertex 2E 60GB SSD would be add a little more 'oomph' to that build sir. I was wondering why you're purchasing Windows 7 Ultimate over...
I'd recommend the Intel processor. Pricey, but Intel are really doing well lately. They're processors are really quite awesome, have been using a...
