Was discounting it for that reason, as Sigma had discontinued it. but they've announced a OS version today, think I might hold of buying stuff...
I made it from black card, a sharp scalpel, duct tape. masking has only ever worked on my prime too, i think the way the zooms move internally...
Tulip and fairy lights, using my 50mm f/1.8 with heart shaped mask. [img] tulip and heart by whisperwolf, on Flickr
Playing with the new camera. blended shot of three exposures. [img] rose light by whisperwolf, on Flickr
Erm... The "click now" remote (ML-L3) works quite handly for the bulb setting on My D50, first click opens shutter, second click closes it. no...
Still deciding, currently up for debate are the nikon 70-300 vr, the tamron 70-300 vc or finding a sigma 50-150 f/2.8. I've decided not to bother...
Well its a newish year so I've finally upgraded. The D50 has now been replaced by a lovely D7000 after finding it for what I think is a quite a...
See thats why for the office I bought an aeropress, is it as good as my Gaggia, no but it still beats every instant I've tried. Plus it's quite...
Erm aren’t most GPs self employed or Partners in a practice. Therefore apart from the few Salaried GPs they're already running businesses and...
The collections thing on the Kindle is rubbish, but comparing it to a rooted nook is a bit unfair better to compare it to a sony reader that...
You can't backlight e-ink screens, they’re not transparent, the best you can currently do is side light them. and if they were backlit you'd find...
if your using the beta version of chrome, in the options > content settings you can set exceptions to Javascript, blocking forums.bit-tech.net...
for a Cafetiere it would currently Galapagos Organic from here http://www.thebeanshop.com/shop/detail.asp?prodid=100034 For espresso or latte I...
Well have to say I'm disappointed. I do dislike stealth advertising and whilst I acknowledge that advertising is needed to keep things...
my favourites from this year. [img] Well it is Valentine's (2) by whisperwolf, on Flickr [img] Daffs and Spring 4 by whisperwolf, on Flickr...
reliability mostly, if the slave cell is positioned where it won't see your flash it won't go off, so if you using a flash outside to light a...
hello check out here and search some of the threads here. but check to make sure the radio trigger you buy has a pc sync lead. so if you want...
tea - black with 1/2 sugar Coffee - before 10am in a latte with 2 sugars after 10am before 9pm - black with 1 sugar after 9pm espresso with 1...
I've take the ereader as a change in how I purchase books, I'm not really interested in books I already own, but it does annoy me that if i...
very easy if its in mobi format and not DRM protected, I use Calibre to convert non Mobi books and transfer the books to my kindle. It won't...
