I'd recommend Onkyo for an AV Receiver/Amp. Superb value and highly recommended. I'd also spend £50 on a massive rug to cover a larger part of the...
Hmmm. Yes. 'Overkill' doesn't quite do justice does it. :duh: What exactly were you planning?
Thanks T2I3M.:thumb:
Upgraded to FF4 this morning and since doing this I can't access my work Email Portal. Just doesn't work. Sooo annoying. I had a saved version of...
Agreed. I have both a Pure & Roberts. I prefer the Roberts myself. Fantastic sound quality and functionality.
I've had similar thoughts when I first had a look through the forum. So much so that I've just ordered a P183 to transfer my rig into. I'm going...
Hmmm. But 5 x regular transfer speed? That's quite a claim.
500GB Spinpoint failed 2 weeks ago. Strange though because it seemed to be electronics. i.e. as soon as I switched the computer on something...
Decided! I'm gonna build my best rig into a new P183......AND use my existing Themaltake Armour as my spare rig / test bench. Means I get myself a...
Thanks Jipa. I'll probably go for a mid-league case with good access and removable mobo tray for now. Thanks A seed has definitely been planted...
OMG. That really is sweet. Haven't seen a picture of it all set up before. I mustn't.......no....It's wrong...............but.............
Me too it's sweet! But my wife already thinks I'm a nutter and I figured that something that can pass as a "Computer" would be far less likely to...
Hi all, Simple question really. I'm building a spare/testing rig and am keen on a setup that make testing & swapping out new/old components as...
