Just want to get this off my chest as it's really put me in a bad mood today. Back in 2011 I purchased a set of Corsair XMS3 RAM, started...
The RAID-5 array on my Windows Server 2008 shows "Failed", with a single drive showing as "Missing", assuming this to be the failed drive I have...
Just want to let off a bit of steam regarding my recent experience with Amazon and an unreasonable buyer (one of many unfortunately). I list a...
I am using a HP Microserver as a basic home fileserver/media PC. Until recently this had 2x2TB drives, and 2x3TB drives, each as a RAID1 array. I...
Seem to be having an issue with getting PCs to connect to the internet. Only a very brief explanation, and I'm sure more information will be...
I'm basically looking for some advice with regards to the best way in which to go about achieving the following network setup. I wish to have a...
I'm having some issues trying to send a faulty 690 off for an RMA. Basically it was purchased on another forum, and was DOA. I don't have...
I have a PC with XBMC installed, using Ubuntu as the base, unfortunately this is an old version though, and the other week it decided to break and...
I placed an order for an item worth around £50 from eBay on 03/01. On 08/01 it showed this as being delivered. However the proof of delivery did...
I am attempting to use the built in Windows 7 mirroring capability, however I have run into some problems and wondering if anyone knows how to...
Am looking at purchasing this case, does anyone happen to know how loud the included PSU is? Have been looking around for a while but can't...
What is the cheapest place to get this case from? So far I have found it at Scan and CCL with CCL being the cheapest including delivery....
I am looking at building a really cheap HTPC that will allow me to play 720p and possibly 1080p files on my TV, the only problem is that I need it...
I am thinking of maybe getting a HTPC, but our TV does not have a VGA, DVI or HDMI input, it does have the component video which worked fine with...
So, I was using my PC on Saturday morning, all was fine, turned it off and went to turn it back on this morning, pressed button, fans and lights...
It seems the latch that is used for the flap on my case has broken, so I need to find something else to use, the latch looks like this: [img]...
So a month after getting a new bike for getting to and from college it gets stolen, the lock and everything. I am looking for a new lock that...
Would anyone be able to tell me the length of this card as I have not been able to find the dimensions anywhere, thanks.
Am looking to buy a new PC soon, but am wondering if it is worth waiting a month or not before I make the purcahse?
Building a PC for a friend on a budget, he basically wants something that is fast, good for multitasking and will easily play games. Here is...
