Well we used to live in the New Orleans metro area and my home was damaged to the point where we could no longer live there. We lived in 'St....
OK... I'll answer them 1 at a time. #1) Not really. A VPN makes it seem like you are actually on the network. It's like having a VERY long...
Well port forwarding just sees a request for a specific, then sends that request to the proper computer, with no secure access involved. VPN is a...
I'm running v5270 on my system and it is running smoother and faster than XP is. There's a few programming glitches that I have to deal with, but...
When I set mine up, I just ran Prime95 for about 15-20 mins... that heated the cold plate up enough for it to set. Never had any problems with...
I use Arctic Silver 3 on mine. Still have quite a bit left in my tube. I just put it on with a razor blade like you do on the CPU and screw the...
I will NEVER again buy a Maxtor. I got one and it's been replaced 3 times and all 3 times it's died. I will probably go Seagate from now on....
Well unless you have a transformer, the bulb will not operate. As for the best, don't really matter much. I'm using 2 ModWare UV cathodes in my...
I have started a new case (sorry no camera so no pics) and I have hand etched my plexy but I am looking for a clear paint or perminent clear dye...
This might be just a thought, but why not just pole them correctly and attach them to your HSF on the inflow side instead of trying to reverse...
I use the "K-Lite" codec pack with WMP9 and it works great. I also use the program that comes with it (BSplayer) for better quality. You can...
Got to looking around and came across this... http://download.com.com/1200-2001-5075068.html?tag=tid Might be exactly what your asking...
Using a set of Cambridge SoundWorks SPF2000 Digitals. Never really been able to push them so I ain't baked any of the speakers or the sub yet....
You can try "IBM Via-Voice" or maybe even "Dragon Naturally Speaking". Both are voice recognition programs, but what their limitations are, I'm...
Nice... it looks close to the one that I'm designing now. Doing all the design work in 3DSMax so that I don't screw anything up in building it...
Man that is some serious glowage. What did you use to get all the different colors from the different OE parts? I like the way the fans are...
If you have an idea of what you want, sketch it out on paper and then let someone that knows graphic programs have a go at it. On a private board...
using a CoolJag JAC103C.... a monster 533g solid copper HS with a 60x60x25mm 7000rpm fan. It's noisy but my CPU never climbs above 32ºC so I'm...
I've been dealing with depression for about 13 years now without medical treatment. I realized that most of the time, my depression set in...
I'm not sure about making a circuit for something like that, but I do know that they have alarm clocks that do that. I couldn't tell ya what...
