Crashed my 84 Ford Thunderbird, So I bought another project car to fix up. 1988 Mazda RX7 13b rotary, perfect interior, ac, ps, sun roof, cd,...
Random Kenwood MP3 deck JL 3piece Component speakers RF 200.2 JBL 1200.1 amp 2x Infinity Perfect 10.1 D Sounds fine. Awaiting a new car...
Get a ok webcam and get motion sensitve lights. Mount the webcam in a unseen place and make sure its one that can be software activated by...
This is the origonal engine, the tranny is not. However the car was a 289 2bl with C4 auto origonaly, so im getting it as close as I can.
I do lots of body work, welding, painting, so my basis comes from that. Always wear eye protection for cutting, painting, even sanding bare...
Lcd window? And dont paint the radiators fins, bad thing to do if you want good heat transfer!
If you arent planning on painting the exterior, epoxy or fiberglass it on the inside. You could also bondo the outside or fiberglass it..
Why not do a luvered vent for the fan, jbweld bolts on the inside so nothing shows on the outside other then the vents?
Oh and the Straight six... gone in a few days ;) [img] Its a 289 C code, bored .060, performer cam, 600cfm holly, Elderbrock Performer 289...
The 302 replaced the 289 in late 67, after my car was made... And I hate to break it to ya... But 302 blocks generaly only take 500hp before...
It got another layer off fiberglass and resin gel... Now to sand!! [img] I need to take car of that surface rust!!! No more wiring harness.......
Test image being hosted from above link.... My brothers 68' Buick [img] Had to even out some previouse bondo.... [img] And Ive reached...
1968 Buick Sportswagon with Vista Cruiser glass. 350 V8 bored .030 over with a hydro glide tranny. We have... lets see.... 10 cars. Im working...
Anyone know where I can find another host?
Its outside!! Well, as soon as I got it outside it started raining. (Our neighbore droped off a tree in our driveway while no one was home,...
Not bad! But the ps was simply just upside down.... :worried:
Yes, thats what I use to mass format harddrives before we give them to students/recycling programs.
You need to find a different host for your pictures, theres many that other forum memebers offer.
Ford guy, muscle car guy, hates rice guy... My F150 pulls 300hp stock, my 67' stang pull 350hp modded, and my 84 Tbird pulled 278hp modded....
Wo wo wo, When the hell did hp/compaq start using this case? I have not see one at comp ussr, circuit city or best buy, Its blasphmy that they...
