plenty 680i SLI boards around on the 2nd hand market for £60, so no more than £120 will get you to 8800gt sli world :), just make sure your psu...
I understand not wanting an OS, but it is a way of checking all your stuff is actually working properly as far as the supplier is concerned and...
it it a video output issue or is the whole machine freezing/shutting down ? could it be a hibernate feature you've accidentally enabled ?
my hunch is Vista is scanning the data, my HD on the Vista machine also seems to be a lot more active than my XP Pro machine in general use
only getting 10mb/s, seen a few reports of this on other sites, but wondering if anyone here has experience of same issue and hopefully a fix...
I use a thine line of silicon glue on noisy coils as it is more compliant when cured [i.e. the clear silicon sealant stuff ], or if your lucky to...
deja vu or get the same kit from Euro PC and delivery is a tenner, FYI my Dell M90 [M1710 chassis] with t2300, 1 gig ram, fx1500m, 60 gig...
does your mobo bios support dual core?
http://www.europc.co.uk/pages/ProductPage.aspx?PID=82356 Grade Dell Refurbished Model Precision 390 Colour Black on silver Cabinet / Case...
keep an eye on Euro PC for a precision 390 workstation, there aren't any cheap ones atm [just 2 x X6800 extreme machines] 2 weeks ago there was...
have you left cmos reset jumper on "clear" ? I also remember when I 1st powered up my asus p5w I thought I had connected all the power cables...
just checking, we've had a few at work which have shown a bit of a weakness in the power connector area [mind you they get some serious abuse, so...
http://forums.bit-tech.net/showthread.php?t=126593 already explained here that high 80's/90's were fine, why are you still asking same questions ?
a bad battery can cause such issues, remove battery and see if it runs on mains only btw is it a dell 8500/8600 by any chance ?
contact cleaner aerosol :)
http://www.amazon.co.uk/Intel-DY674A-PCI-E-DX6100-DC7100/dp/B0002Y5LZI
have a look at battery contacts, they can oxidise over time and start acting up
hope you also removed battery in case the liquid finds its way under the keyboard, if you dont feel comfortable dismantling, leave it in your...
please don't post this rubbish, you are clearly misinformed I upgraded my fx1500m to a 2500m last week, it is pretty commonplace to do such...
its a cad laptop :), but the card is G70 and performs same as a lower clocked 7900gtx yes there are 2 gig ram modules available on the net for...
