Great sponsorship MaG :rock: Very nice the light effect and also the color on the Slotin !!! I am curious... where did you install the leds to...
Very intersting render and the first step you've done it's well done :thumb: Am I wrong or your plywood has a different cover on each side ?...
A little jewel :clap: The fluorescent yellow plexi is fantastic :jawdrop: as the pump stand :eeek:
Hi guys, here I am with some updates! Let's skip from the front side to the rear one :D I took the frame from and old case, but it was too long...
Why do you need all those radiators ?!?!? :worried:
Nice chassis, man!! :thumb: I think the hardware position it's not so bad considering both that your cpu is not so "hot" (tdp 65W max) and...
It looks amazing anyway :jawdrop: I didn't understand how you keep in place the CF once you turn the mold to cover the other side :eyebrow:
The case will be Not So Small , but with the psu in position of the previous image......my htpc will be too high :nono: After cutting the...
