I have managed to tweak it to get in a GTX 560Ti - the only question is - can I run the i5 and this card with a 530W PSU? My initial though...
Aaah now I get it - the answer would be most definitely not! - Was just my subtle use of old time English and no reference to such a famous...
Cool thanks for the replies. Had the argument of 6870 v 560 with myself earlier before posting and was hoping that wound't come up again - but...
Cool - makes sense. OC wise - I''ve never experimented with it so guess that's no issue. Now the only problem is making some form of sound and...
Ah sweet ok then will have a look into that. Is there a maximum speed/rate that an i% can use? Thought I read somewhere that 1600MHz is the...
Have another query regarding pricing up some components - do love opinions! Chap wants to build a new rig on £700 that's capable of playing BF3...
Cool that should work! Seeing as though I had the thread open I started looking at mini-itx - just to see what was around. Has anyone heard...
Thanks for the replies guys! Looks to be some good ideas coming up. Think I have settled on the Intel Core i7 2600k - give some nice power...
Ok then, never really looked into amd much before - ive mainly focused on tge intel sides of things. What would be a good amd combination to fit...
Hi again, Have a slightly bigger build question this time...in a way. I have been asked to help put together a PC for a mate at uni. The only...
Cool thanks for that - as long as it fits then I'm happy!
Hi, We need to add a new graphics card into a PC a work - in order to get a second monitor going. Does any one know if an Asus GeForce 210...
Haha thanks chaps, Have disabled hibernation, changed the default Windows User account folder to the old HDD and default install and decreased...
Ah sweet! Didn't want to miss out on any "greenyness" :D Will see how it all goes from now, looks ok still so time shall tell! Thanks for all...
Hey, Ok just installed a new SSD and now have my old hard drive as a backup. Does anyone know a good way to force remove old Windows files?...
Thanks for the reply. Have been fiddling with it and seems there was something wrong with the SATA cable. Swapping it over seems to have done...
Hi again! Finally finished exams and got the drive in with the new parts today. Is there any special requirements to get the drive to boot? I've...
I would agree with that to :thumb: there needs to be more info like this out there that's useful and easy to read. If you do I would read over...
Ah thanks for that! So as long as the drives aren't under constant use then it should be fine? My PC isn't on all the time and not usually on...
I'm more interested in who went to a toilet to smell the urinal cake before tasting one of the drinks on test :P (hope that was on the custom PC...
