Hey ch242, I really appreciate you looking into this, you've obviously given it a good look through!! I searched for vValu16ToDec() on the Jennic...
:) cheers for the suggestion Firehead, but it didnt work, I get the same error. I think it is going to be more complicated than I want it to be!!
azrael, I am writing it in C :) Thanks for your help ch424, but where is the function vValtoDec()??
Oh i apologise, I am writing in C
Hi there, I hav u16int variable that I want to output to an LCD screen on a Jennic JN5139 evaluation board. The function to do this is...
Hey thanks for the responses. I have checked the avis out in gspot, and found a couple of Divx and a couple of Xvids, and they both have this...
Hey there, this isn't an issue which is gonna kill me but it sure as hell bugs me! When I playback any .avi file, the very top and very bottom...
I can't share between the host and VM in any way arf. I have logged into my router and looked at attached devices. Is shows both my Vista...
Hey there, I am running Vista, and have VMWare Workstation set up to run WinXP. What I would like to know is how to set it up so I can save...
:rock: rock on, thank you very much! :)
I understand about data fragmentation, why it is fragmented and how it is fragmented... My question is why isn't it rearranged until it reaches...
aaah JazzXP that is a brilliant way of doing it :clap:. I found a little tutorial about creating a Wizard programme using cardlayout. It had...
ah right, I see what you both mean. Either way would work just as well I guess! For what you said shadow12, would you need to create a new...
Right, I am trying to learn how to make java GUIs, just for something to do really. I am using netbeans IDE. I have a database set up with...
:worried: Why would you be opening your monitor?? Bad idea if ya ask me!
oh yeah haha, i didnt notice that :D There isn't actually any example is there! doh!
yeah, basically using classful IPs, you got ABCD and E. You can tell their class by their first octet. A = 1 - 126 (127 is reserved for...
:) cool, thank you for confirming my thoughts. I think I might have the hang of it now. For anyone else learning about subnetting I found this...
It is the 240 hosts on each subnet that confuses me...Would you not just use 255.255.255.0, and have 256 subnets with up to 254 hosts on each??...
Hey there, I am revising for a retake in August (:( Need to sort it out!!) which is on TCP/IP net admin. I have a past paper, and the question...
