When copying locally on your network your wifi has to cope with the data twice, source to the router then router to destination. You will see...
I've had success with Recuva before https://www.piriform.com/recuva
Just found a post on using the bullet on a yacht :) http://freedomyachts.org/viewtopic.php?f=7&t=10145
Get yourself an outdoor AP, like the Ubiquiti Bullet2HP add on a decent omni directional antenna and you'll have a solid connection to the marina...
The cheaper option is to just get new wireless AP. You can disable wireless on the BT router and just use then AP. Then no matter what any future...
Be interested to know what the turn by turn navigation is like on that, I've got the 500 and it only has breadcrumb navigation.
On MS Windows... Link Aggregation at a software level was only just implemented on Server 2012, previous to this it was specific to...
done. http://www.ubuntu.com/download/desktop/try-ubuntu-before-you-install
It's pure scaremongering by the news about catching Ebola, if you were planning a break in certain African states I might re-think it, but within...
I use postbox, not free but it's super sleak and works perfectly with gmail and IMAP.
So you can only invoice for work once you have a physical signature? Ouch. You'll need to go down building something custom if that's the case as...
So all you want really is ticket tracking and billing for time spent? Almost all Help Desk Software will do this for you. There are plenty of...
Firstly you need a switch that supports link aggregation, as this feature is enabled specifically per port. If your current switch cannot be...
Windows 8.1 because Windows 7 will not support DirectX 12.
http://www.acoustic-energy.co.uk/#!aego/cgnd I always recommend the Ageo M... they are 2.1, great sound quality and very high quality...
https://ello.co Anyone a member? Any thoughts? If there's any invites going begging I'd like one to see what all the fuss is about...
ANPR cannot track vehicles in real time, this would require having a camera on every street in the UK. All that the Wikipedia article says on...
I live in a village with 15 houses and close to no through traffic ;) I cannot be guaranteed that I will not pass a mobile unit, but again it...
Ouch that's a badly written driver. If it's running as a scheduled task you can remove the echo lines as you won't see the console output:...
Depends how you class a "journey". I start my journey when I get into my car and drive through my small town, there are no ANPR cameras...
