hi, Mine was built firstly has a second machine that i could carry on the plane to Australia with us (as i couldn't bear to be without a pc for...
hi! Cheers dude, will try that thanks :D
Hi, Had my shuttle for a few weeks now and i'd like to have a go at overclocking,and i was wondering if theres a way of monitoring the temp of...
9800 pro hello again last night i fitted the 9800 pro (fresh install)and it rocks after a few mis haps, to cut a long story short it turned out...
9800 pros going cheap hi, if you take a look at komplett they have power color 9800 pros for £176 ish and thats a bargian the only catch is they...
New card has arrived! Hi well today at last my replacement card arrived :D and as you can guess from the smiley i am,completely amazed they sent...
update on 9700 pro hi, today had a very nice man at crucial on the phone he says they have tested the card and cannot find anything wrong but he...
thanks thanks for your support but the card has been RMAed back to crucial for testing well have to see what they say :sigh: hopefully it can...
I just bought a crucial 9700 pro and its fine with most stuff games ect but just hangs then doesnt output to monitor when running Enemy Territory....
yup uninstalled old drivers on both machines :D its working a treat now was a corrupt ATI control panel problem.
Hi When the card was first tried both 2500's were put back to normal speed for testing to remove any errors caused by this. thanks Bob
tried in msi board same results at first then tried install but just basic drivers no ati control panel and it ran better.so did a complete...
yup, in the procces of trying in a system with a kt4 ultra mobo(MSI). ill post the result soon as we have finished. :D
Molex plug hi yes the molex plug was connected both tests :thumb:
hI all, A friend of mine has just fitted a new card in his pc an ATI 9800 XT and is having problems the card hangs after about 2-3 mins. The...
