correct: v3 charger charges blackberry, but apparently blackberry charger doesn't charge v3... for anyone interested the ipod wall socket...
That's my assumption as well. However, someone said that it doesn't charge their Motorola V3 Razr, so I was wondering if there were any other...
I've got a Blackberry wall-socket power adaptor which outputs 5V 0.5A DC to a female USB socket - can I use it to charge a 4GB iPod Nano?...
What bios does it ship with? Some reports of problems with v1.7 and v1.9 with that board - try v1.6 - k8n_neo_platinum_bios Otherwise, as...
Da Dego, I suspect that there's a lot of ppl like me who would like to build a full gaming pc and stack it with their hifi. So any reviews...
How about building a quiet HTPC? So finding cases with decent-sized fan mounts (i.e. not 60mm) or obvious modding potential?
I think XP Home only supports one cpu, but it does support dual core on a single package? If I run Prime 95, setting the processor affinity to...
cheers guys - Hitman's linky looks good and I'll have a play tomorrow - have to celebrate Ashes victory today... :clap:
Hi All, Q: What clock timings should I set my Corsair XMS-XL to? 2-2-2-5-1 is obvious, but what about the Bank Cycle Time (Trc) and the DRAM...
PS2 would give your mouse its own individual IRQ, whereas your USB controller will share an IRQ with other random onboard components or a PCI...
Hi msm, Q: why Overclockers? They used to be really good (I bought most of my bro's pc there a year ago), but prices seem to have gone up. Eg...
Hi riluve, FWIW the num lock didn't work and I did try flashing the bios using Hitman/Asus' instructions. Nowt. If, when you borrow a...
Hi All, For anyone searching the forums with a similar problem to mine: dead mobo. Plugged working components in and still nowt, RMA time...
Hi Roto, why do you think it's a knackered PSU? Hi Webby, any idea which forum or whether they have an answer now?
I've no idea what bios it ships with. I was under the impression that it should still boot up as a single core if the bios doesn't support dual...
Hi All, If I connect PSU to mobo and hit the 'on' switch then the new-fangled 'Post Reporter' on my shiney new Asus A8N-SLI helpfully tells me...
