I'm assuming that you're using command-prompt and not proper DOS. The easiest way to run the file would be to copy it into somewhere like the root...
DVD Shrink Can re-encode the DVD to fit on a single layered DVD and saved as an ISO if you want to leave it on your system to put on a DVD...
I forgot to mention that I was on NTL cable. I've just plugged the laptop into the router with the cable and it seemed to be fine although it...
Well I finally changed my router as my old one kept dropping all the computers frequently. I've just got my Netgear WGR624v6 yesterday but now...
First time I played I did the same thing.... shamefully it took me a few goes to realise shooting didn't have an effect, nor did running towards...
YEY! :clap: Thank you :thumb:
I've only just starting learning SQL & PHP from online tutorials and the like. I'm betting that there's a really simple solution for this but I...
Thought I'd post mine: Me Av Paranoid |||||||||||||||||||| 86% 49% Schizoid |||||||||||||||||||| 86% 53% Schizotypal...
Just Googled it and aparently THIS software can do it. But like I said, it's just a Google result so I've never used it.
Have you tried the Maxtor Big Drive Enabler. Although it's by Maxtor, I believe it works with any drive. Link I've had countless problems...
I mainly use media player 6 if possible, mainly due to the fact of pressing space to pause whats playing. Really wish they hadn't changed that in...
Just Googled it, it runs silently as part of Office. Was the regcleaner you used an automatic registry editor? I've had bad experiences with...
Sounds like the motherboard (dodgy SATA controller). I'm personally not suprised that it didn't work when you installed Windows onto the...
First off, sorry if this has been posted before, did search but couldn't see it. Anywho, it's apparently the first windowed hard drive to be...
Are you using the drivers from the cds? Maybe it would be worth a try seeing if there were any newer drivers on the internet?
I've been teaching myself a bit of PHP today, my first dip in the serverside pool in fact. I've been wanting to learn PHP for ages now as it's the...
What do people think of having an arranged game sometime? Maybe Wednesday if that's not too short notice.
A very similar thing happened to my old wireless router, right before it completely died. Lost all wifi access so had to connect with the wire and...
That's quite amusing actually :) Reminds me of melting my transformer toy when I was a young'un. Sat him down on a lamp and forgot about him...
If you put in the XP cd and boot off it into the Windows Setup, there should be an option to format the hard drive or partitions then you can do a...
