I've got everything up and running with a Gigabyte P55M- UD2. But also bought the crucial 300 ssd after the initial set up. I'm having a few...
Hi, just got an SSD drive and was wondering if there are any boards out there that support 6gb sata drives without down grading the Pci- e slot to...
Hi to everybody again. Memory problem sorted, now looking into a bit of overclocking. I tried the spec as in CPC mag but whilst running prime it...
Just to update, i've now ran Memtest86+ on one stick of ram, 22 pass's no errors. I put the other stick in and 'bingo' continuous errors! Now been...
Set them at 1.66v as there is no 1.65v in the bios and also changed them to 2T instead of 1T default.
Glad I passed mine 32 years ago! You could ride a 100mph Suzuki X7 on L plates back then! :)
The memory's running in the second and forth slot (white), which is what the manual suggested it should be. I haven't tried different slots as...
Sorry should have read 2x2Gb Corsair!
Hi, I've just updated my computer to a spec as in the Custom pc mag. A Gigabyte P55M-UD2 M/B, i5 760, 2x 2GB Corsair XMS PC3-12800, AC Freezer 7...
