Could you not just get an EPIA 500Mhz and use a couple of 300GB drives in it, Amount to pretty much the same thing... (Unless you want to spend...
Yeah i think you have a point. Although she wownt be doing much gaming, she will be doing plenty of graphics work. I read that the semperon's...
So I’ve bought a rack mount case (unfortunately for my credit card they seem to be my fetish of the month) for my itx epia 5000. I’m now deciding...
I have the NEC 3500A. After burning various disc's the quality seems excellant and its much more quiet then any drive ive had previously.
Im building a computer for my sister. As i have been out of the computer game for a year i wanted to make sure that this list sounded ok. Im a...
lepre. You are very annoying.
sorry had to add this... I presume by the no-brainer american mumbo-jumbo you mean that its ovious that they are different. Hmm, same shape...
Ok girls, 1) When i was a kid i was jumping off and on a round-about. I slipped and my leg got caught under it, The round-about kept on going...
Thanks ill take a look.. ;) Have you used your kvm with a unix machine ? bit worried of spending £X then it not working correctly...
Ok ive had enough... If you have several pc's youll know what i mean, desktop clutter. So im thinking 1 4 port kvm and a decent mouse a keyboard...
Antec Minuet ?
Have you seen the antec minuet, i think thats the one ill be getting :)
Ok so its $89... hmm so that means in this fair an even world ;) it will be around . . . . . . . . . . . . . . . . . . . . ....
I know nothing of these boards, but the missing ram is probably going to gfx and the bus speed is either set wrong or reporting the bus speed, so...
Can we add to the list "Card crackles in analogue mode, card crackles in digital mode" :) gets rather annoying after 2 years of trying to...
Ive had this problem, psu wasnt delivering enough power. I have also had a problem with a small bit of metal shrapnal was shorting the...
Yep i know i have split personaility post syndrone
for some strange reason i want to get the underdog, but it is for my server so ill guess i will probably get the tagan (or both)
That including vat or excluding, cheapest i can find is 71 + p&p the akasa is 57 + p&p Ive always liked the idea of 1 single 120mm fan,
