Use 2 of these to create a wireless bridge and then a regular access point (or router in AP mode) for the clients to connect to. Sure, it's a bit...
You'll want an outdoor rated directional AP, or if your ambitious, run a cat5e cable to one one of the guest houses and add an access point.
A near Darwin award recipient makes the news because the fire she set off didn't burn her face or cleavage. For those of you that don't have...
No, unfortunately not. The next step is to see if you have a 3-pin to molex fan adapter and test each fan and see if they work. You can do it...
I assume your using the 3/4 pin connectors on your motherboard? If so check in your BIOS and try modifying the case fan settings. Also try...
Cisco's small business lineup (200,300 and 500 series) is also quite compelling and is relatively affordable.
So long as (with a name brand PSU) the peak power isn't consistently above 80% then there's not much to worry about. If you're gaming every day...
1920x800 - medium - x264 - RF18 - film - main - 4.0 - AAC 2.0 = 5.6GB I switched to my dual x5660 server (12 cores (I didn't give the VM any HT...
Just got ahold of a 4K @ 24mbps copy of an un-superhero movie (strictly for testing purposes of course). First test 1920x800 @ medium RF17 AAC 2.0...
Parking This doesn't get old. She's a wee bit singed, but it's 1000x better than a RUD LHqLz9ni0Bo
It's above my pay grade too and what little I know (besides how to google) comes from watching the EEVblog. Unless you had time to kill and a...
It really depends on the low voltage cut-off of your camera. Alkaline sags under load, whereas NiMH starts off lower (full charge is 1.4V and dead...
Much better idea. By all accounts, we had a pretty mild winter, though the Syrian refugees who ended up here suffered a wee bit of a shock to the...
I found that it really depended on the content - police procedurals with lots of static scenes compress really well and Mythbusters only...
Port the number to a cheap voip provider and just run a sip/iax client on your company phone.
Stacking is designed for 3-8 switches with a common uplink (and a desire for simple management), but if you're connecting 2 or 3 switches in a...
Surely this must be a 16 or 14nm die (shrink?). If even 1/10th as many 4.5s sell as the vanilla version, that still accounts for 4 million units,...
Try mapping it as a network drive. Also, try: Control Panel\All Control Panel Items\Credential Manager\ >>>>Add a Windows Credential
I really want a high speed camera. v_Ga8m-otEE
At least we learned our lesson with the internet and went with IPv4 addressing. ... Sh|t, nevermind.
