As a rule I always put the res above the pump (where possible) but ALWAYS make sure the res is before the pump in the loop: res > pump > rad >...
What response have you had from Scan?
As I thought, cheers Chicken
In CPU-Z under the Memory TAB it shows my memory speed as 665.5Mhz, is this the actual speed or do I need to double it as its DDR? Many Thanks
Many Thanks Rob, anyone know if there are any plans to reinstate the leaderboard?
Sorry if this has been covered elsewhere but I was just wondering if the CPC benchmark suite is still available and if the leaderboard was still...
Hi all, I am looking at using my rig for folding, it is a Q9650 and 3 x GTX 280's, can someone please tell me how I go about using my GPU's, I...
Budget and main uses for rig??
Have to agree, use cheap PSU's at your own risk, it will usually end in tears though!!
Should be good to go, its not a radical change from the 920, somebody correct me if i'm wrong though.
In a phrase.........EPIC FAIL!!!!
Magic fellas, thanks for your advice. Like I said it wont be getting built till I am back from here at the end of May so I guess i'll wait and see...
Hi all, right i'm currently planning my new build for when I get back from Afghan at the end of May. The system will be used for gaming and video...
I'm interested in seeing pics of this set-up :-)
Will run again tomoz with a Q9650 in @ stock
They all seem a little low, this is my score using a Dual Core E6750 overclocked to 3.5Ghz and 2 x GTX 280's at stock. [IMG]
And also Cheese Sarnies too Mmmmm!!
I have never had any problems with www.watercoolinguk.co.uk so can recommend them. Cooling that lot I would def go for 2 loops, no problems with...
Is this referring to the upgrade offer via copies of Vista or something else?
Cheers for all the advice, I think I will stick my old copy of Win Xp on and see how I go from there, if I have any issues I will be sure to ask....
