thanks noiz thats what i thought and have now found some 19" with the right pixels, I have also found one from the same manufacturer as my 28" so...
not sure i know what you mean there can you expline what you mean by the resolutions will be further apart thanks tim
dont worry mate i was confused to start with, so phicially then i want a 19" 4:3 or a 17" 16:9?
cheers cleggy thats great to know and I have looked at that card which seems great. unfrotunatly it dosent use a referance design so cannot get a...
:confused::confused::confused: what I did was look at the pixles for my screen and then looked for screens that had a similer number. when I...
thanks mate Thats exactly what I am looking for (look at my post above) sorry missed your posts I am a slow typer :duh:
sorry my fault i was actually thinking of the ti but apart form the CUDA cores is there a need for it???? I have never overclocked before but am...
Hi all, I am currently lookking to upgrade my current pc with a graphics card and have settled on the gtx 560 but I was hopeing for some answers...
thanks tehboris I understand that it was not going to double my connection speed it was more that I wanted to make use of what I had, I dont...
Wow that was quick thanks glider sorry for my noobness but when you say uplinks you mean broadband connection right, also what did you look for on...
Hi, I was hoping to get some help with setting up our network at home. Long story short we now have 2 phone lines with broadband from orange, so...
Hi all just wanted to say thanks for the advive it worked like a charm :thumb: i no longer get the annoying message about the bios update. dosent...
Thanks Bindibadgi i have to go out now so will give it a go later and post back hopefully:D
Thanks for the quick reply Deders ASusupdate:- update BIOS from the internet-next Select the update server:- ( passive is ticked) auto...
Hello everybody, first post so please be gentle, i was hoping for some help, the problem i have is that i have built a pc (£400 future proof pc...
