but do they need to route? You can also use them as a switch, making everything a lot less complex...
Save yourself headaches (now and in the near future) and dismiss all the RAID0 you have... Also, just add the drive to your system and use it as a...
The only ones to ask are the admins...
Is there a specific need for the 3 routers?
Not at all... On the contrary, it offers no benefit, while it adds a potential for more data loss... Don't bother with it (anywhere, not...
Well, it's easy to illustrate the bi-directional part. Say a pipeline crosses an electrical railway. Under normal circumstances the power source...
Well, it's for inspecting the coating of a pipeline. We put a specific signal onto the steel tube, which is (in this case) 1.6s on, 0.4s off, but...
Hi electronics guru's! As you all might have guessed I need some help designing a high speed switch for work. Currently we use specialised gear...
Seems like a badly finished beta... Something like Windows ;)
I don't see any choices that oppose a PPD... We (as society) gave the burden of law enforcement to the Police department, and they don't do a bad...
Country: Belgium In City: Sometimes Method: Car Distance: 2-150 miles Time: Too long to worry about ;)
So by default it's an 'automatic' kind of thing, but users who deem a post extremely helpful (or quite horrendous) can PM a mod to ask for a boost :)
Every command or just every command with 'sudo'? Can you post the contents of /etc/resolv.conf, /etc/hosts and /etc/hostname?
This is quite weird, as 'ls' doesn't require any resolving, it just lists the files in the current directory... Seems you have quite a borked...
If you just want a NAS, get a low power (~P3 600 ish) system, throw a Linux distro and a gigabit NIC on it and you are set.
I still don't quite get the use of the system... Do mods award rep automatically, or should users PM them for it or what? Maybe this can be...
Nope, ifconfig is the command to use. With iwconfig you set the SSID, encryption and the likes :)
I was going in that direction ;) NAS boxes (at home) are more then suitable as routers, with an enormous flexibility ;)
If you ever get sick of FreeNAS, throw on Debian and you'll even have a more powerfull machine ;) (If you need help with it, I'll be glad to...
Not at all, you are bridging connections, which isn't the same as routing (NAT)
