Anyone know where I can buy/beg/steal/borrow one of these in the UK? (its the black plastic 'frame' around a 478 socket) I took it off the...
I went to a gig last night at the Cluny in Newcastle, and saw these two play..... It absolutely blew me away .... I was gobsmacked. Imagine...
just like it says on the tin ...... (and yes, I did :search: :D ) my 19" Ilyama 454 crt has just died (after ony 3 and a bit years of use I...
.... and lets face it, if you got rid of Intel, then AMD would be the 'bad guy' looking for world domination .... variety is good
Can anyone recommend a decent book on HTML? I've been looking at the O'Reilly guide to HTML and XHTML, but I'm open to suggestions ......
Thanks for the input everyone - just thought yo might be interestded to know I finally found something suitable (I hope), the Gigabyte NX66T128VP....
Cheers bigz, I'm looking forward to your review Any idea when they might be available? Olly
Can anyone recommend a PCI-E graphics card with a passive cooler? It doesnt have to be the most powerful card on the block, but I do need a...
Anyone seen any reviews / know anything about this monitor? Done a search on Google but cant find anything. I'm in the market for a new TFT...
lol - yeah I suppose that might be true :D , but its not so much what they say (and I think I can follow most of it) but the way in which they...
Nothiing against you personally slater but most of that crowd on procooling are so up their own backsides its unreal..... :D but hey I'm a...
Yeah Nexxo, that was about the only one I've seen - just wondering if there are any (better) alternatives out there. Thanks anyway :D Olly
Hi, does anyone have any suggestions for a good external USB soundcard for about £50-£100? I need to improve the sound on my Shuttle PC but I've...
coolermaster praetorian (in black) :D
Any suggestions for the best headphones to use for gaming - preferably with a built-in mic ... Cheers, Olly
If you're going to use the Innovatek passive rad, just remember it was designed for 8mm systems, not 1/2" - it would probably give a lot of flow...
I use AquaComputer gear in my rig and would highly recommend it ...... Let's me get an 800 MHz overclock out of a 2.4c ! Olly
something like this ? Olly
whoops ........... I'll just slope off and hide in a dark place then :blush:
