did you create shares on the machines you want to access files from? all on the same workgroup? are they all grabbing IPs from a router? or are...
sweet, good job. later
if you just go to file -> save as in either IE or FireFox it will save the page, and create a folder in whatever directory you saved the page in....
i think you actually have to set the height like that (per tag basis) to get the height and width from js. not 100% sure on that. good luck...
ok, to get the height, you want somthing like this: height = document.getElementById('blah').style.height; i hope that javascript is right,...
hey pumagt500, how do you like your N200? i've been thinking of getting one. thanks! later
sure, www.dyndns.org thats what i use later
also, you will generally want to forward port 21 to your server for ftp. later
i use a K62-400 running Debian Linux/PHP/Apache/MySQL and it works great. i haven't installed an ftp server on it, as i have no need for one....
if this is not exactly right, sorry, i'm not at my XP machine right now. i'm assuming you're on a workgroup and not logging into a server....
cool. i just checked, mine are 32ohm. i think this stuff is over my head right now. i don't even own a soldering iron, much less am i able...
i am intrigued by these headphone amps. why do you need them? soundcard's built in amp not good enough? how do you use them? through the line...
give this a shot: http://www.vmesquita.com/en/diko.htm then use nero to burn the image files it creates. this program encodes dvd and svcd,...
sweet, thanks. i got a ton of good info over at the carstereo.com forums. nice people over there. answered my newbie questions very quickly....
ok, i'll ask this last question, then go to that site from here on out. ok, so say i have an amp that takes speaker line in and has a built in...
thanks alot. something i just remembered. like i said, i don't want to amp anything but a sub for some punchy bass. i'm using the factory HU,...
yeah, i figured i'd buy the rear speakers from crutchfield. when you buy a speaker that is recommended for your car, they send you an adapter for...
sennheiser HD202. use whatever sound card of the PC i am using at the time. soon to have a muvo also, if the keeper of the funds (wife) allows...
ok, i've read alot and done some research, but haven't fully installed a system myself. fixed the stereo in my wife's old car (just a bad ground)...
you could do what laoda said about making the image a BG, or you could throw the text into a <div> and use CSS to position it where you want it....
