I know that the Title is a little misleading, I'm not sure what the technique is called, but. I am repainting a laptop, the LCD is my primary...
I've downloaded Xubuntu 8.04, How do i go about setting it up to run games (ie: Quake , BF2 , Doom, etc..) as a public server? The Games aspect i...
I'm trying to figure out how to remove C:\Program Files (x86)\misc from being added when ever i install a app. Anyone know how to do this?
I'm trying to figure out which EVGa 680i mobo to get any suggestions?...
I'm pretty sure its going. but you can advs me if its not. I have a WD 200gb hdd use as a slave (store all me stuff on there, except windows)....
Anyone know of any good Progs that block sites that are innapropriate?
[not sure if this would b the proper place to put this] I'm looking for a UMPC (Ultra Mobile PC) just for WoW. I've seen the samsung q1, but...
I have a HP laptop ( HP Pavilion DV5000 ). And just recently the lcd has been acting up. Getting gamma distortions and over bright lines on some...
K sad week this is been for me. 1) My crt's RG(B)lue cable is broken so im getting only red and gren out of it 2) My powersupply may b on...
I need to replace the VGA cable on my monitor (ViewSonic E90f ) the connector to the videocard is bent all out of shape and im only getting Red or...
Does anyone know what are some good camera's for security? Minor or high security. I want something that i can access from the net at anytime, but...
I want to buy a SLI laptop from Alienware when it comes out and im thinking of the heat. SLI in a small space is like frying 20 eggs at once. So...
I went to go uninstall AIM in which my sister decided to install when she wasnt supposed to and noticed this wierd thing happening with the...
I have a problem where my _NEC DVD-RW ND-2500A isnt reading dvds anymore, but it reads standard cd's fine. I did just update my windows Serive...
Pimping.
Would it b possible to take a steel briefcase and put a computer in there then add a 19LCD monitor to it so you have a portable desktop PC!? Or...
I need 2 questions answered hopefully i can ge tthem answered here! I'm planning on buying a WD 40gb hdd for Redhat linux. The problem is i...
I bought a WD (Western Digital) 200gb 7200rpm hdd off newegg.com last year and i havent had any problems with it untill now! My problem is that...
Well today hasnt really been a good day since i blew up my GPU fan. Literally! I was cleaning the dust off with a air gun! probably 160lbs of air...
I'm probably not the first person to ask this but as a fresh new member that wants to break into the modding field of PC and al ltheir goodness,...
