Right now my primary hard drive with the bootable OS is hooked up to an SATA controller that leads an SATA cable to the SATA port on the mobo....
I'm looking into upgrading my system ram to 2gig DDR400 (2x 1gig). Right now I'm eyeing on the Corsair XMS Pro 2gig (TWINX2048-3200PRO) for my ECS...
I was just browsing the nvidia website and came across the quadro cards. Not only do they still make another kind of video card, but it also has...
This started out with the new release of Shadow Warrior's: Wanton Destruction expansion pack installation package when I noticed it would only...
Hey there, I do a lot in the command line. Right now I'm using some DOS16 apps to do some of my work on my XP machine. But here recently, I...
What is the main reason why I would have to install chipset drivers for my computer? My computer is running fine! Seriously though I try to do...
Well I don't work in flash, but I do know that sometimes advertisements on the web that use flash can take a whole 100% CPU usage. The first...
I just installed a 64-bit mobo AMD 3000+ with 512MB of PC2100 ram along with a Gigabyte 6600GT, having a copy of XP Professional. Everytime I load...
Well, I hate to post in a wrong forum, but this question of mine seems best to go here. I got about 4 case fans going right now and I'm about...
Well I've got about 4 of them laying around, if not 5. And two of them won't pass POST on a working machine. I was just wondering if anyone knew...
I got this case from an old friend and the case was recieved to me with a modded case door (The Popular Antec one, Black) with a window detached....
I got a SATA 150 card that will let me use SATA cable with my hard drive. If I install it, is it recommended that I reinstall windows? Do I have...
Hey guys! I upgraded my system to a Althon 64 3000+ with 512MB of PC2100, a Nvidia 6600GT with an Audigy 2 Platinum, a 250GB hard drive and 2...
Will this power supply do the job for my 64-bit mobo+cpu? http://www.newegg.com/Product/Product.asp?Item=N82E16817101106 Specs:...
What is the best 16-Bit Sound card out there? It can be from any age. Just would like some opinions on what people thought was the best card...
Hey there, I have an MSI mobo, a MS6380-E v1.0 bios v.5.7 Last time I updated the 4n1 drivers, it seemed to lag the system on startup a bit...
I need to find a very very cheap power supply that will support an AMD-64 bit mobo+cpu. The one I have will not support the new 64-bit. I...
Right now I have a AMD Athlon XP 2000+, 1Gb of PC2100 Ram, a Geforce 6600GT, and a 420 Watt Power Supply. I want to upgrade to a AMD 64-bit 3000+....
Does anyone know or know how to get the list of all the windows commands? Like I know if you use run you can type in "sndvol32" and it will...
I just got an AMD 64-Bit mobo+cpu. I hooked it up to a case with a 420Watt power supply, and made all the necessary connections. When I...
