I recently got my hands on a PC with windows 2003 SBS installed. I'm only using it to test around things (will get reformatted at some point)....
This did the trick! It worked, I could visit gmail.com from another profile, so it must have been something in the default profile folder. I...
Local hosts file in windows is bypassed since we are using a proxy. Java/Flash is as updated as can be in Windows 2000. I am not allowed to change...
@moorsey: Thank you for you time. Firefox settings are indeed set to the same proxy as the one in Windows control panel. Still no luck, gmail.com...
Hello, I have a minor problem accessing a website from my work PC and I would like to ask how I can resolve it. I run Windows 2000 (I know...)...
I agree 100%, raid5 as main OS disc is not wise. I'm trying this as we speak. I also took images (through a live ubuntu cd) of the 3 healthy...
I tried connecting a new hard disc (larger than the other 3, as I cannot find a same one) as a replacement, is shows up as "non RAID disc"in POST...
so, I should kiss the raid5 goodbye? It really strikes me as odd since Raid5 was made for exactly this scenario (1 hd fails) but I cannot seem...
Yes I am sure. Owner of the PC remembers setting a RAID5, and it's what I see on the screen of the Matrix Storage Manager (RAID5). Checked all...
Owner of the PC does not remember a system failure prior to this. Just the PC refused to boot into windows one day.
Hello, a friend of mine had a RAID5 set up in his PC, with 4 identical hard disks (4x WD1500 ADFD-0 150GB) on a ICH9R controller (built-in on...
Hi to all, we have this NAS http://www.intel.com/support/motherboards/server/ss4200-e/sb/CS-029881.htm directly connected in our LAN (10 PCs,...
Hi to all, I was using windows XP (on a 4GB hd, as master) and debian linux (on another 4GB hd, as slave). I was booting from the xp hd, using...
The hd has 50GB capacity, and all the 50GB are in a single partition.
Hi to all, I have a rather peculiar problem with a friend's HP ze4900 notebook. He had some problems, so he decided to reinstall windows XP....
Hi to all, I'm very new to linux and I have been assigned a project: write a command line linux program in c which will read a mpeg2 video file...
Found a solution here http://support.microsoft.com/?kbid=817472#kb6 but after a while the drive stoped working at all. I've taken it back....
well, I left 3dmark on for too many hours as it seems and the fan wasn't placed very well. card burned! never mind, worthed the try. thanx for the...
The problem was with the DMA: it was off. I removed the drivers from the device manager, rebooted, and when they were reinstalled, DMA was back...
First of all, what is RMA (I'm Greek)? to take it back to be replaced? The problem exists for all the source discs I try. All original, in good...
