How do I write a SQL query involving a time stamp? QUOTE_ID is a character string CREATE_DTG is a date time type RETENTION_LEAD_TRACK is a...
How do I solve issues with adding Tabbed Control with Expression Blend 3 for Silverlight App? I am using Microsoft Expression Blend 3 +...
How To Modify An Element in the Dictionary Class? ======================================= C# has this cool Dictionary class that you can use...
C# Split String Not Working =================== Please Help. I wrote a C# program that reads code one line at a time. Each line has data...
In a silverlight app, I have a BitmapImage defined as System.Windows.Media.Imaging.BitmapImage and it as a method called "SetSource" where I can...
I am trying to go from 32 bit Vista to 64 bit Windows 7. The 32 bit Vista was installed by mistake. My system can handle a 64 bit OS. Now I...
Help me Convert this WPF to Silverlight I am interested in a Charles Petzold C# example that shows how to do a fisheye effect (...
How do I get a dattime format in C# that will look like this: 2011-09-01 00:00:00:000
I have a question about Silverlight on the Client Side. Silverlight is designed differently where it is not possible for a silverlight program...
TextBlock wrapping of text in Silverlight XAML file. I have a wierd and annoying problem. I have a textblock that is inside a stackpanel that...
When editing an XAML file using visual studio 2010 sometimes the tick marks to colapse groups are there and sometimes they are not. Can anyone...
Can anyone tell me anything about manifest files? Anything at all. I have never worked with them until now and they are a mystery to me. I have...
Hi Forum! This is my first post. This doesn't seem to be a computer programming forum. Is it? In case anyone knows, is there an ActiveX...
