Hi, I'm looking to build a gaming PC to sit in the living room and plug into my 40" HDTV. Looking to play anything from CS:GO, Skyrim, Dota2,...
Hi, I'm looking for an extremely cheap PC for my retired mum and dad. They just browse the web and use MS Office, so I don't need cutting...
Hi there, I'm trying to fix my Sister's Dell Inspiron laptop. It's running Windows Vista 32-bit. After pressing the power button, you see the...
My business partner and I live in the UK. If we were setting up, say... a web hosting company which uses dutch servers, what is the best way to...
I've recently bought a laptop which will be used as a desktop replacement, however I have a 750GB 3.5" SATA drive (formatted as NTFS) that I need...
I'm in the UK and planning on purchasing a Dell, which lists no option other than to have Windows Vista Home pre-installed. I'm aware that the...
I'm looking for a dirt cheap hard disk recorder for the parents. Preferably with a built in DVD writer. £60 or less, ideally. - Don't need a...
I've not flown since last summer and I realize that the hand luggage rules are changing all the time. Can anyone, who has flown recently, on an...
I'm looking for a case that will take a full length PCI-E card (around ~25cm). Any suggestions?
I'm setting up a new server and I'm having problems getting it to boot my Windows x64 disk. Asus P5WDH Deluxe Intel Q6600 2x2GB PC5400 RAM...
Well, I've exhausted Dawn of War. Most players with an automatch score of under 1500 are generally fairly easy to beat and it's getting quite...
I'm looking for a portable audio player that has over 100GB of hard disk space, will play FLAC files and supports dragging and dropping of files...
British and Dutch police have shut down one of the world's biggest sources of illegally-downloaded music. A flat on Teesside and several...
I'm looking to buy the following patch cables: - 20 x 10m - 4 x 15m They can be either Cat5e or Cat6 (whichever works out cheaper). The...
I need a small box that is ultra quiet (I can't sleep with my main PC on), that can be used to be left on 24/7 for file serving and downloading....
I'm looking to set up a new bank account for a non-profit organization. We're a student society but need a decent current account in the...
I'm looking for some kind of application that emulates all of the different browsers out there. It's for web design testing and I really don't...
I'm looking to find a small javascript that will alter the following code into an instant-response toggle image. <form action="lol.php"...
I'm looking for an ultra small (mini-ITX or smaller) motherboard that will support a 1066FSB core 2 duo processor. It should have a 16x...
I'm looking for dirt-cheap 2U cases and a ~10U rack. Any ideas? What's the cheapest you can find?
