I went searching, but could not find information on this, is it possible to convert Firewire to USB, with a converter plug of course. Thinking...
Alright, I am going to probably take 6-10 blue LEDs and arrange them inside my LianLi cover, so theyshine out the front grill, however, I want...
Alright, since the job has picked up, and I have cash, I am currently looking into both new keyboard and mouse, as well as a cd-rw dvd combo...
Alright, I posted before, but got little advice, so I post again, as months later, I still hold the same problem. I installed my nice SCSI...
Sound driven LEDs. Just as it says, the light will be shining down basically in the space between the fan and the acctual front, the leds unseen,...
what program you guys running to make your pcb layouts etc?
I'm not good with electronics, never learned it, i'm good, I just don't know down in-depth technical details, and many who float around here...
Alright, i bought my VFD with everything this time, eventually i'll get to the LianLi panel, with a dremel, but for now, this works. How do I...
Alright, this is my second MS optical mouse, I love them, its the four button, wheel optical. I having problems, its happened on both, its like...
I think we all need our own little BiT cheesie, with its little leaf and everything. It can be BiT's little action figure
Alright, tonight, or already, I have began plans for a new project, since I have a lot of cash, and will be comming in contact with a car soon, I...
Anyone know where to buy this at, website unless a major chain in USA, pref texas. Need something 150watt, or lower. Oh, if someone knows a...
Alright, setting up mp3box, but how did you draw power, and from what source, the cig. lighter? I don't see that pumping out enough juice for...
Well, with the introduction of SCSI to my system, my IDE CD-rom does not work. Well, it does, but windows will not recognise it. In Windows...
Anyone know where to pick up tachometer for hdd usage and temp or something, has to be small enough to fit onto a floppy drive cover.
RIght now I am thinking about a new system, and I am looking for a motherboard. Really, I want something like the shuttles, that small, but still...
Well, with the boredom, I am starting on an more electronic project then anything, about to make this pen of mine into a speaker, I will give a...
Alright, I am designing a simple layout site using PHP and CSS, but what I want to do with the PHP is quite complicated. I have a small...
Alright, I have had this happen before, but I cannot pinpoint what is causing this. Windows will SLOW down to all hell, and now that is its...
Well, I have been browsing around for a while now for a dvd cd-rw combination. I will more then likely not go with slot load, as they are prone...
