Kodongo thanks for the informative post. I will certainly change up my PSU to the seasonic!
Guys, this is why I come to you! Thanks for the advice and rest assured changes made! Thanks again
Hi guys, I tweaked the build a touch and i've ended up planning on getting the following, just hoping to run it past you guys to make sure its all...
Why they don't include their own 'classic look' setting is beyond me
I think I will settle on Windows 8 but use that mod to make it look like Windows 7, I cant be without my start button and I would want to do away...
Or, if your using the wireless switch out to a pair of powerlines adapters. I did recently and now wont go back to wireless!
Windows 7 or windows 8 guys? Thanks for the help so far
Any response guys?
Thanks for all the help guys. Learning every day!
Thanks guys, I will get that Dell then that you suggested, which cable will I need?
probably sounds a bit stupid but would the screen still display HD even without using a HDMI cable?
The only issue I see with the Dell U2312HM is the lack of HDMI input? How do you get around it?
Hi, I'am looking for a monitor upgrade for a gaming PC. Nothing too flashy, but ive seen the buzzword IPS screen splashed about recently?...
I just checked my RAM and its 3 x 1GB Corsair XMS 800Mhz thats in my existing PC. Thanks
Greetings all, I am new to the forum and I just wanted to see who would be kind enough to give me some advice on a new build and somebody local...
